Re: C123 crank pulley
Posted by snoopnc on February 21, 2015 at 17:55:44 from (66.44.248.5):
In Reply to: C123 crank pulley posted by hillbilly2 on February 21, 2015 at 17:43:39:
if its a groove from a worn oil seal, take the sleeve to NAPA or any good bearing / seal place and get a "speedi sleeve" to slip over the shaft and give you a smooth surface.
  Upload Photo  Select Gallery Photo  Attach Serial No List
