Re: C123 crank pulley
Posted by Janicholson on February 21, 2015 at 18:54:53 from (63.152.239.119):
In Reply to: C123 crank pulley posted by hillbilly2 on February 21, 2015 at 17:43:39:
If it is a thin metal tube slipped on the snout where it goes into the cover, it is a speedy sleeve and can easily be replaced with a new one. The new one will/should come with a seal. If it is wear directly into the snout, the solution is the same. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
