Re: 301 valve timeing
Posted by fastfarmall on February 21, 2015 at 20:57:50 from (24.92.172.177):
In Reply to: 301 valve timeing posted by ericsegaline on February 21, 2015 at 17:31:06:
the way i see it, the marks on the cam gear are essentially the same, and since the cam turns half as fast as the crank, use either one of the double dots, and the use the double dots on the crank gear, If the cam had a [two sets] of single dots, then u would use the single dot on the cranks gear, or did i miss something, but i never worked on a 301 either !!
  Upload Photo  Select Gallery Photo  Attach Serial No List
