Re: Farmall 560 Diesel questions
Posted by redjohn on February 22, 2015 at 05:26:07 from (173.87.12.44):
In Reply to: Farmall 560 Diesel questions posted by kevinj54 on February 21, 2015 at 05:18:24:
Everything looks the same in your picture, as this tractor. However, the spring is in place of the clamp for the cable, and another bracket was made for the cable.
Thanks for the advice on how long to activate the glow plug button. We were only holding in for about 30 seconds. But sitting in the shop last night, without heat on, it did start. We had 14 degrees overnight too.
As far as testing the glow plugs, I had the charger set on 2 amps, and held long enough to see some smoke coming off the glow plugs.
Does the glow plug button pop right back out, when you release it, or does it slowly come back out. This one comes out slowly, and when pushing it in, you need to push on it, as there is some resistance.
you also mentioned the timing wasn't quite right on your injector. Did you take the cover off, and reset, or did you do it running, to tweak it?
