Re: pictures (snow removal)
Posted by rankrank1 on February 22, 2015 at 08:22:05 from (166.137.14.92):
In Reply to: pictures (snow removal) posted by Ellis Kinney on February 22, 2015 at 07:51:44:
Tells us more about the heated seat. (e.g. your fanny heats it?, you use the little hunter chemical throwaway packs?, or a real genuine heated seat like snowmobilers would use powered off of 12 volt battery power?)
Also what kind of hitch you got on the ole M. Fast hitch or 3 point? Got any rear view pics of the hitch and blade.
