Re: floating hydraulic outlet international 300?
Posted by janicholson on February 22, 2015 at 09:58:13 from (199.17.6.210):
In Reply to: floating hydraulic outlet international 300? posted by realolman on February 22, 2015 at 08:48:18:
The OEM IH control valves have a switch on the end opposite where the lever attaches. (front IIRC) this switch is a flat projection on a round valve component. It has a roll pin through it that is under a sheet metal (tin) "limiter" one position is S for single acting, the other is D for double acting. If you switch between them it might give you the desired effect. I also believe in skids or wheel based limiters at the blade edge to prevent gouging, and allow contour of the ground to be followed. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
