Re: 460 hydralic problems
Posted by tleake on February 22, 2015 at 12:24:50 from (68.104.242.194):
In Reply to: 460 hydralic problems posted by tleake on February 21, 2015 at 21:00:28:
UPDATE
It has the teledepth valve. Piston is stuck in valve. Small gear that works between outside control lever and teledepth linkage has stripped teeth. This is why the 3 pt that was on the tractor when I bought it was plumbed into the remotes on the right side of the tractor, middle control lever, instead of plumbed into the back, outside lever. I will have to rebuild the teledepth valve, find that little gear and linkage for teledepth. I have the rod that runs under platform, but everything else is missing up to that shaft sticking out of the nalve on left side.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
