Re: FARMALL 140 HELP
Posted by Andrew Z on February 23, 2015 at 04:53:30 from (72.10.102.45):
In Reply to: Re: FARMALL 140 HELP posted by RUN-N-LATE on February 23, 2015 at 04:46:05:
Do you have a diode wired into the system? If not the alternator will back feed and keep power going to the coil.
Look at Bob M's wiring diagram, and confirm you have it wired accordingly.
Andrew
  Upload Photo  Select Gallery Photo  Attach Serial No List
