I believe the M is same as the H, and there is no adjustment on the H. I finaggled and foozled arund, and tried various things, finally wound up rotating the sector gear, installing steering box seals [ had none in mine, as I found out ]and replacing the worm gear with shaft, ordered from this site. It was a fix. Steers tight and perfect.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
