Re: Farmall M Wide Front Steering Free Play
Posted by David G on February 23, 2015 at 07:44:14 from (204.29.138.33):
In Reply to: Farmall M Wide Front Steering Free Play posted by Jim R on February 23, 2015 at 07:18:51:
There is really no adjustment. I ended up replacing all the gears and bushings on my H, now it steers pretty good, it is just easier that way.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
