Re: Farmall 806 Help
Posted by mazemeister on February 23, 2015 at 08:41:55 from (104.148.251.168):
In Reply to: Re: Farmall 806 Help posted by tneathery on February 23, 2015 at 08:30:50:
the camshaft has to be timed to the crankshaft. then the injection pump gear has to be timed to the camshaft gear. the static timing is then adjusted by the injection pump gear having slotted holes to attach to the injection pump. and the exact timing spec depends on which injection pump you have.
  Upload Photo  Select Gallery Photo  Attach Serial No List
