I know next to nothing about the particulars of the Long brand, but a tractor is basically a tractor, and a clutch is a clutch. Fiirst thing to do is make sure the clutch is properly adjusted, with the correct amount of free travel.
Another thing to consider is that sometimes, it takes awhile for the transmission gears to stop spinning after depressing the clutch pedal, and you're not going to get the trans into gear until it does stop spinning.
If none of this applies, then you have no choice but to split it.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
