Re: Farmall M - I can't find a oil filter - HELP!
Posted by Owen Aaland on February 23, 2015 at 19:20:44 from (216.47.34.37):
In Reply to: Farmall M - I can't find a oil filter - HELP! posted by rlkend on February 21, 2015 at 13:48:06:
when the M was first produced the oil filter consisted of a fine wire mesh screen. These were soon replaced with a paper element that could do a better job of filtering in a smaller size. The M filter base was made smaller when the paper filter became the standard and the smaller tractors continued to use the same diameter filter base but the canister was made shorter.
The serial number break when the filter size was changed was engine number 59393\59394 so your 42 M may have come with the larger base. In that case it may have been converted to the aftermarket filter to upgrade to a better filter than the tractor came with from the factory.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
