Re: Re: Re: Re: Re: Re: H won't run
Posted by RB on January 14, 2001 at 07:04:34 from (63.27.121.135):
In Reply to: Re: Re: Re: Re: Re: H won't run posted by REA on January 14, 2001 at 05:48:23:
I may have missed something here,but do you have a live wire running to your mag?You shouldnt if the mag is right,it should be one wire going to the cutoff switch and thats the only wire on the cutoff switch.(Unless you have something riged up like I did once)The only thing 12 volt should affect with the mag systen is the starter and charging system,12 volts wont hurt the starter but the charging systemwill need upgrading.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: H won't run
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
