Re: IH Farmall 350 transmission fluid change
Posted by Charlieu on February 24, 2015 at 05:18:15 from (206.8.2.191):
In Reply to: Re: IH Farmall 350 transmission fluid change posted by drake9898 on February 24, 2015 at 04:16:00:
The first thing I do when I get ready to remove a pipe plug is take my 2 lb. hammer and give the plug a couple good wacks. It's surprising how it helps.
Moving onto your clutch not releasing, I bet if you pull the TA lever back you can then shift gears. Your clutch & TA linkage needs to be readjusted. When you push the clutch pedal in you have to release both clutches (Main & TA clutch)
Take a look at your manual and adjust away. I'm sure your problem will go away.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
