Re: 400 fast hitch
Posted by rhtx55 on February 24, 2015 at 15:17:42 from (68.191.209.251):
In Reply to: 400 fast hitch posted by rustyone on February 23, 2015 at 18:49:06:
there were two styles of fast hitch for a 400, the one pictured above is the early style. it has two cylinders. The large one in the back is for raising & lowering the hitch, the small cylinder on the side is to raise & lower the hitch point. There is also a junction block that attaches to the rear remote on the battery box, this block has a relief valve inside that prevents the hitch from leaking down and retards the lowering of the implement slightly, you will also need the u shaped drawbar.
The later style is called fast hitch with traction control and this hitch has only the one large cylinder in the rear but will also include a large D shaped handle with notches that comes up to the operator's left rear of the platform, this adjusts the amount of draft & weight placed on the rear tires for increased traction.
If you can provide a photo or two of the hitch you purchased we can help you identify which style you have & which cylinders you will need.
This post was edited by rhtx55 at 15:19:29 02/24/15.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
