Re: Long 460 Clutch not disengaging
Posted by Mark Robke on February 24, 2015 at 15:58:49 from (75.89.158.116):
In Reply to: Long 460 Clutch not disengaging posted by Triliji on February 23, 2015 at 12:18:19:
No matter what brand it is,you need about 1" free play in your pedal as a general rule.Too much free play will not allow the clutch to disengage completely(and none will cause it to slip).And you may need to wait a moment to put it in gear-for them to stop rotating.If you start it in gear with the pedal depressed,does the tractor try to move? If it does and the free play is correct,you probably do need a new clutch. Mark
  Upload Photo  Select Gallery Photo  Attach Serial No List
