Re: Farmall 300 upgrade with strange results
Posted by 1958johndeere620 on February 24, 2015 at 18:55:04 from (142.0.96.98):
In Reply to: Re: Farmall 300 upgrade with strange results posted by D Slater on February 24, 2015 at 18:15:02:
I did loosen the front or governor side of the tube so maybe that is where a small change took place. What I did to correct was take the pin out from the throttle shaft on gov end. Then backed off the lock nut on the adjuster block to turn it down 2 turns on the threaded rod that comes from the governor. That got it back where it should be. I wish I had tried to loosen that tube first, but o well live and learn. The timing was to advanced at the old setting. I had to retard it maybe 10 degrees or so. I will put a light on it when I am done. I also gapped the plugs out to 45 thou. Lots more to do and it won't stop snowing long enough to finish it. Thanks!!!
  Upload Photo  Select Gallery Photo  Attach Serial No List
