Posted by jal-SD on February 24, 2015 at 19:31:46 from (208.53.222.164):
In Reply to: Farmall h hood problem posted by dinselm95 on February 24, 2015 at 18:41:38:
If you had either the radiator or gas tank off, (or both) each may be off of the original positions by just a little. (Remember, the back of the hood rests on the front of the gas tank.) If each one is off 3/8 of an inch in opposite directions, you could have that 3/4 inch total easily. Also check the brace rod that goes across the top of the head from the gauge bracket to the radiator support and make sure the radiator is as vertical as it should be. My bet would be the radiator is out of position, if you had it off. (My $0.02 worth.jal-SD)
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
