Posted by D Slater on February 25, 2015 at 05:41:17 from (184.14.187.78):
In Reply to: Farmall h hood problem posted by dinselm95 on February 24, 2015 at 18:41:38:
Whenever the radiator is removed and installed I like to mount them and grill, leave the hose clamps and bottom mounts loose. Measure the hood both sides, then move the radiator as to get close to the hood measurements from where hood rests on tank to grill. If its good on measurements at top and bottom check for steering shaft and shroud clearance and if good adjust the top support to the correct distance. Sometimes things don't work out and you compromise. Or do some modifications. No adjustment on the fuel tanks unless other work is done. If hood gap is closer near bottom or top of tank end needed can be spaced up a little.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
