Re: 1939 famrall H propane No Throttle response
Posted by djsamuraii on February 25, 2015 at 09:00:23 from (199.27.156.4):
In Reply to: 1939 famrall H propane No Throttle response posted by David G on February 25, 2015 at 08:32:08:
Thanks for all the responses. Like I stated earlier. I'm a new bee at this. But at the bottom of the carb is what I'm assuming is a choke. It needs to be opened all the way for the tractor to start which it does. But you can hear the propane escaping. and if I close the choke the tractor dies so I'm running it wide open. any suggestions. If I close it the propane leak stops but the tractor doesn't run if I close the choke all the way. I'm going to get a regulator rebuild kit. Would it be a good idea to get e carb rebuild kit as well? Or change the entire system to IMPCO? Suggestions are all appreciated..
