Re: 1939 famrall H propane No Throttle response
Posted by TKelley on February 25, 2015 at 09:27:17 from (67.20.235.129):
In Reply to: 1939 famrall H propane No Throttle response posted by djsamuraii on February 24, 2015 at 08:01:03:
I have a 400 LP we had trouble similar to yours but not the same. The tractor starts with the choke shut all the way, when the tractor fires open choke all the way. you need to be certain that you have a good gasket between head and manifold, part of my problem was a bad manifold which I replaced with a new one. I also fund that my regulator was not working properly because of vaccum leak and hole in diaghram. Replace regulator and cleaned carb. Tractor run great and lots of pulling power. Governor has to be hooked up works like a gas tractor. Hope this helps some.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
