Get the correct ones from CaseIH and be successful in your rebuild and overhaul. The upper one is p/n 356782R91 or 361086R91 which are optional to each other, the lower gasket is p/n 356799r1. There is also an oil seal required p/n 356784R91 which is noted as part of the valve body. You also need (2) 350667R91 O-rings where the manifold tubes attach to the valve body. You most likely have two issues you are dealing with which are size and cross section shape of the O-rings. Good luck, Hal.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
