Re: solenoid fuel shut off valve
Posted by The tractor vet on February 25, 2015 at 19:11:33 from (104.179.81.68):
In Reply to: solenoid fuel shut off valve posted by buffchevy on February 25, 2015 at 17:20:11:
Yes that is what it was made for and i will also add to this , Check your ing. timing and check the ideal speed with a good tach. Check for proper heat range on the spark plugs and stop using cheap gas .
  Upload Photo  Select Gallery Photo  Attach Serial No List
