Re: 1066 steering motor leak
Posted by The tractor vet on February 25, 2015 at 22:50:49 from (104.179.81.68):
In Reply to: 1066 steering motor leak posted by DeWayne Utrup on February 25, 2015 at 21:47:31:
Well did ya check MCV pressure or just STUFF the spring kit in and call it good ???? As for the leak it more then likely is the seal under the steering wheel and easy fix . The hardest part is getting the steering wheel off , here ya need two 1/4x28- 6-7 inch grade 8 bolts a 1/4 x28 bottoming tap and a steering wheel puller . But you need to check MCV pressure and it needs to be around 265 -275 psi.
  Upload Photo  Select Gallery Photo  Attach Serial No List
