Re: Gas tank inside coating.
Posted by farmeracb on March 01, 2015 at 17:35:03 from (70.195.71.129):
In Reply to: Gas tank inside coating. posted by Janicholson on March 01, 2015 at 15:53:32:
No.
Farmall tanks are hard to clean, and harder to coat. Any liner I have had experience with has had a failure at one point or another and then the tank is junk. You are time and money ahead to let the fuel do the cleaning, install a standpipe in the tank and a filter in the sediment bowl, and plan on cleaning both at each oil change.
This sounds bad and like a lot of work, but it is better than having the liner come apart and having to try and find another fuel tank and match a paint job.
Adam
