Tom Fleming...F-12 F-14 idle metering jet
Posted by seth boyer on March 03, 2015 at 06:24:50 from (174.125.76.99):
third party image
third party image
third party image
Tom I just wanted to share with you what I have found on a few carbs I've been into. This is the third 29953-DC carb I've tore apart and I've discovered they all had the same metering jet. Those of you who don't know this carb is the factory gasoline carb. 29954 is the Kero special/ distallate carb. I haven't seen the small port in the side of the jet you've mentioned in the past. I'm curious which carb you've seen that on? I'm running a 29953 brass bottom carb on the tractor now and I can't remember the design of the metering jet on it. I do remember the overall design seems to be a lot different than this later model cast iron body carb.
I hope the pictures explain themselves.
Sorry to bring this topic up again. I may just be a little obssesed with learning the differences in these carbs! Haha
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
