Re: Farmall M Belt pulley drive to run hyd pump
Posted by oldiron29 on March 04, 2015 at 17:38:25 from (74.88.8.65):
In Reply to: Farmall M Belt pulley drive to run hyd pump posted by PretendFarmer on March 04, 2015 at 17:21:04:
As David G. said below add a live pump.
If you run it off pto every time you push the clutch in your pump will stop.
I know a guy that mounted on the side rail a live pump and ran it off the crank pulley. Not alot of fab work to set it up that way either.
oldiron29
  Upload Photo  Select Gallery Photo  Attach Serial No List
