Re: 340 ih revs to high
Posted by kub6040 on March 04, 2015 at 17:46:19 from (173.202.168.240):
In Reply to: 340 ih revs to high posted by jmducks1 on March 03, 2015 at 17:55:15:
Your gas 340 would have a governor like a 140 or 240 It should run about 2000 rpm but should be ok slightly higher . You will want to remove the radiator to get it out easier I think you will find a broken spring , but I suggest checking and replacing bushings while you are in it as they will make a lot of difference in how the governor works if they are worn out.
  Upload Photo  Select Gallery Photo  Attach Serial No List
