Re: Governor Problems? 51 Cub
Posted by john *.?-!.* cub owner on March 05, 2015 at 11:55:02 from (99.195.153.11):
In Reply to: Governor Problems? 51 Cub posted by equeen on March 04, 2015 at 19:58:30:
The hand lever pulls the spring tighter to pull throttle open. Governor fights against it to keep rpm ant proper level. If it only pulls spring a little with engine stopped, the pivot shaft at the spring lever probably is rusty and binding, and needs lubed. Or if this is a new to you tractor someone may have installed wrong spring before you got it.
