Re: Fast hitch and TA questions
Posted by D Slater on March 06, 2015 at 10:54:27 from (184.14.175.12):
In Reply to: Fast hitch and TA questions posted by Mark Robke on March 06, 2015 at 10:14:59:
When using low side of the t/a without coasting and the ramp and roller assembly holds, the t/a pressure plate or release bearing does not turn. Release bearing only holds pressure plate fingers down and T/A clutch disc only turns. When going to the high side then the whole T/A clutch assembly turns with the release bearing not touching the fingers if adjusted correct.
