Posted by Cory Schmidt on March 06, 2015 at 14:50:18 from (64.246.253.39):
In Reply to: 706 mcv? posted by Jrw013 on March 06, 2015 at 08:44:33:
Did you check the obvious thing first, the fluid level. Got the same problem with the one here. Rebuilt the MCV in fall when the TA was replaced. Worked good till it got cold, now it works some when warmed up. Not sure if a o-ring isn't set right or what. I did dump a few gallons of fluid in when it was warmer from running, but didn't try it cold yet.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
