Re: I don't understand this saddle switch.
Posted by Janicholson on March 07, 2015 at 16:05:18 from (63.152.201.129):
In Reply to: I don't understand this saddle switch. posted by Barton on March 07, 2015 at 11:42:39:
If the starter works, all is well. If it does not, take the switch off and jump directly to the contact with the battery cable. (be sure it is out of gear!!!! If it spins now, the switch may need to be moved toward the contact by using a small chain saw file to slot the screw holes to allow contact. Usually one half screw diameter will do. The amp meter is connected to the big terminal on the switch as well as the Bat cable. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
