656D Injector or valve?
Posted by Montanarancher on March 08, 2015 at 08:35:41 from (108.174.114.147):
I recently installed a rebuilt injection pump on my 656D. The
timing is set at 3 degrees per the manual. The tractor starts and
idles as it should with no issues. When I advance to about 1/2
throttle I start to get white smoke (unburnt fuel) from one
cylinder. I did not have this issue with the old pump. Is the new
pump to much pressure for the old injectors? Should one also
install new injectors with a new pump? I also considered that
bad valve could cause this but did not have this issue with the
old pump.
Thanks in advance.
APF
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
