Picture of front face of transmission where oil flows through the bearings I mentioned. Lower hole has the counter shaft and front bearing and the PTO shaft and bearing taking up the space. Hole below that a bolt goes in it. Large hole at top has the rear of the T/A unit going in it. Its above the oil level also. Smaller hole is near the check plug level and oil level would need to be up to the check plug on level to flow through it. Or it may not they are close. So when you refill through the transmission fill opening the oil slowly flows through flows through the ball bearings and through the lower center housing passage to the front.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
