Re: Farmall C no temp gauge?
Posted by Jim Becker on March 08, 2015 at 16:29:51 from (74.32.103.31):
In Reply to: Farmall C no temp gauge? posted by dinselm95 on March 08, 2015 at 13:25:58:
Your C have a water pump? If so, there should be a plug in the outlet (upper) housing. If not, the factory gauge went into the inlet (lower) housing. If it didn't have a gauge, the inlet housing probably wasn't drilled for it. There is a flat area that can be drilled and tapped with the right size pipe tap.
The Super C had a taller radiator, not sure the Super C outlet will fit. I presume Cliff S has installed one and verified it will work.
