Re: Re: Re: Re: 1066 Update
Posted by Lee K. on January 15, 2001 at 01:32:22 from (205.160.206.85):
In Reply to: Re: Re: Re: 1066 Update posted by T_Bone on January 14, 2001 at 22:36:18:
The dealership in which I worked at had tried an R12 replacement known as Freeze12 to save the money of a convertion. They had nothing but troubles with it. Checking with other dealers they found out that John Deere for a while had a kit in which all the hoses, and basically the whole sytem has replaced. The price was around $800 if I remember corectly. After talking with a few other dealers and auto shops, a few had changed the compressor oil to an R134A compatible oil and flushed the lines with if I can remeber correctly, was air brake antifreeze. I think that the expansion valve was also replaced with an updated one. They never had any troubles with it. The dealership I interned at started doing the simple conversion as described a couple years ago and never had any troubles. To make sure that the system didn't leak, we had electronic reclaimers/recyclers, pull a vaccume for 30 minutes to rid the system of water and check for leaks. If that checked out we added black light sensitve dye to the system when recharging it and ran it, checking for leaks. With the proper oil, no R12 contamination with the R134A, and all the water rid of the system, there is no reason that the seals or hoses should fail. The compressors you buy now for an R12 and R134A system are identical, and use and oil that is compatible with both R12 and R134A. The high side preasure for R12 and R134 varies with ambient temp and moisture in the air. and can be almost identical or up to to a 50PSI or more variation. It also depends on if the system has an over charge. R12 can handle a slight over charge, but R134 expands at a much higher rate than R12. However if a converted system has a proper charge of R134, there is no reason why the old hoses and seals couldn't hold is. And if it is over charges, the system won't cool and the compressor will shut down. This is what I've learned while I was on my internship, and the AC class I took last fall. I'm pretty sure I've got it right.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
