Re: H Clutch De-Greasing
Posted by old on March 09, 2015 at 13:23:47 from (209.86.226.40):
In Reply to: H Clutch De-Greasing posted by FBH44 on March 09, 2015 at 08:50:57:
About the only way to do it is pull the starter off and use the straw that comes with the brake cleaner spray and with the clutch pedal blocked down spray it out. You also need to turn the engine over as your doing it so as to get to the whole clutch. Will also help of from now on you block the pedal down when parked
  Upload Photo  Select Gallery Photo  Attach Serial No List
