Re: Coolant - Extended Discussion - Brian
Posted by Brian Schmidt on March 09, 2015 at 19:52:22 from (72.25.26.58):
In Reply to: Re: Coolant - Extended Discussion - Brian posted by Jim Becker on March 08, 2015 at 20:30:16:
Jim,
I couldn't find an MSDS for the Super Tech
antifreeze online. But what I do see it that it
appears to be an extended life coolant. You should
check to see if it contains a hazardous chemical
called 2-ethylhexanoic acid. This will be listed
on the MSDS sheet. This is the element that
causes issues with gaskets and seals. I would
stay far away from any coolants containing this.
As for colors, there is no rhyme or reason for
them. Coolant manufacturers use color to
distinguish between different blends as well as
provide a color that is able to be seen in the
opaque overflow bottle. Mixing red, yellow,
orange or blue color isn't so much the issue. The
issue is mixing coolant technologies.
Engine coolant is fine balance of additives that
are intended to provide specific protection.
Playing chemist in the field is generally not
recommended. Now if it is an older tractor I
spent $800 on and want to run it, that is one
story. If I just spent $8K on a full rebuild,
that is a whole nother story.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
