Re: 806 Hydraulic control valve
Posted by Brian Stockmaster on March 09, 2015 at 20:14:38 from (166.137.90.64):
In Reply to: 806 Hydraulic control valve posted by showdown on March 09, 2015 at 19:18:16:
Also, you said about lining the threads, would you recommend using anti-seize on something like that. I don't know if it would affect the orings or not.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
