Re: 1954 Super M
Posted by fastfarmall on March 09, 2015 at 22:09:10 from (24.92.172.177):
In Reply to: 1954 Super M posted by PretendFarmer on March 09, 2015 at 21:16:39:
The governor sounds like it's worn out, make sure that pipe,from the front of the head,and makes a 90 degree bend to the top of the governor is tight, and feeding oil to the weights. As far as the 125 lbs of compression, that sounds like the 4 in flat top pistons. That's about 45 hp. The sloppy steering most likely is in the front steering sector, take that top cover off, check it out, tighten or replace as needed. Fill with a tube of corn head greese !
  Upload Photo  Select Gallery Photo  Attach Serial No List
