Re: H Starter SLAMS Into Place
Posted by David G on March 10, 2015 at 08:47:37 from (204.29.138.33):
In Reply to: H Starter SLAMS Into Place posted by FBH44 on March 10, 2015 at 05:39:00:
I do use a thinner starter cable on mine and the newer type drive, it does not bang.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
