Re: H Starter SLAMS Into Place
Posted by old on March 10, 2015 at 09:50:41 from (209.86.226.32):
In Reply to: H Starter SLAMS Into Place posted by FBH44 on March 10, 2015 at 05:39:00:
Change to the smaller auto type battery cables in the 2 or 4 gauge size and or a lower CCA battery or both
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
