When I converted my H to 12 volts in about '88 I left the starter 6 volts and it would do as you say,,,SLAM into the flywheel, but it sure would start good!!! Everyone said leave it alone, it will not hurt anything. A few years later, on occasion, the starter would Lock into the flywheel but I could unlock it by loosening the starter or putting the tractor in gear and rocking it. After about a year of that aggravation I pulled the starter and discovered that the flywheel teeth in ONE spot had been severely chipped from I suppose the starter slamming into it. I had the starter rebuilt to 12 volts and dressed up the flywheel teeth a bit and haven't had a problem since. Thank God I didn't have to replace the flywheel. Now you MAY get away with a 6 volt starter and you may not,,,, Wanna take a chance?????
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
