Re: 1954 Super M
Posted by D Slater on March 11, 2015 at 05:51:17 from (184.14.175.12):
In Reply to: Re: 1954 Super M posted by PretendFarmer on March 10, 2015 at 13:49:42:
third party image
You probably already checked the throttle rod end under the hood. But if not look for bad springs or assembled wrong. If a friction throttle springs can be eliminated. Just don't strong arm the throttle.
Study how the governor works, pretty simple spring pressure overcoming weights to raise RPM.
To be honest I don't use a book. Only thing I set to start with is push the lever on rear of governor down with engine not running, then set the link to have carburetor butterfly wide open.
Then just set everything else were things work the best. Then use a tach to set the high RPM where I want it.
Most times I start by removing the governor, cleaning, remove internal parts and checking and repairing any problem and install a new seal on the operating shaft.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
