Re: Farmall H, how to know PTO speed to run mower
Posted by pete 23 on March 11, 2015 at 10:32:22 from (50.33.21.76):
In Reply to: Farmall H, how to know PTO speed to run mower posted by michaelr on March 11, 2015 at 07:16:15:
The magic 540 speed is reached at rated load speed of the engine. In other words if your tractor is set to run at the correct high idle speed of I believe 1815 on an H it will run 1650 at full rated load . Like others have said, pull throttle wide open and go. You may be able to throttle down some if you like as long as you do the job you intend. The way to tell if you are overloading it when running in a throttled down speed is to just pull back on the throttle and if it does not respond with a little more rpm's you are exceeding the power of the tractor. The reason I added this is because there is a great tendency to overload and engine when not running at full throttle especially if you do not have a tach to watch on the tractor.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
