If Farmall H's or M's have the throttles and governors adjusted properly then the PTO shaft will spin at right around 594 rpm (call it 600 rpm for easy visual on most handheld gauges) at WOT with absolutely no load.
I actually use a handheld stewart warner type tach on the PTO shaft gauge to adjust my throttles to proper spec for both WOT as well as idle speed prior to doing timing sets etc. I have no way to use the handheld on the engine safely since no access, but it is real easy to use on the PTO as long as you know the target PTO rpms for each setting. Thanks to Pete23 and Owen A..land those have been mentinined in some of their posts and I have mentioned it some of my posts as well.
So the answer to your question is pull it wide open and you will be real close to the 540 rpm when there is some load on the PTO. (assuming your throttle is in proper factory adjustment). Only sure way to know is check it especially if you suspect some puller has oversped it in an effort for a couple more hp).
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
