ON that one you will need to pull the deck off and remove the top shifter cover and also the side plate on the left side of the range transmission cover . When you pull the top cover off Rev, shifting fork will fall and you will not be able to reinstall . What you will find on rev. is (1) the key is worn in the rev. shifter shaft. (20 You may find that the detent plate and shifter cam is wore out . , next you will find that you have broken rollers . IF and again IF the Cam is still good you will need a new shifter shaft as the keyway is shot and the roll pin is broken . Most shifter problems are cause by slamming the shifter levers due to improper clutch adjustments and dump valve adjustments. Look back thru the archives as i have covered this in great detail over the years. I have fixed many .
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
