Re: live hyd, Christmas tree valve single action cylinders
Posted by D Slater on March 13, 2015 at 03:25:03 from (184.14.175.12):
In Reply to: live hyd, Christmas tree valve single action cylinders posted by biggerred on March 12, 2015 at 19:48:03:
Depending on what direction you want to operate the valve to lift and lower plumb one of the pressure lines to flow free back to the reservoir.
Plumb other pressure line to the divider.
Depending on the condition of the Christmas tree spool valve the loader may leak down compared to using the side ports on a liftall unit, since they have checks. If checks work you probably notice when a heavy load is on the loader it takes some pressure pushing on the operating rod to push check ball off the seat.
Also didn't add that you need a pressure relief valve between pump and valve if going straight from pump to valve.
This post was edited by D Slater at 03:28:14 03/13/15.
  Upload Photo  Select Gallery Photo  Attach Serial No List
