I know the splines for the steering arms are both good. I've had both steering arms off and had to use a puller to get them to move. These are tapered splines and they fit together really tight. I've come to the conclusion that I'm going to live with this problem until I can find a steering gear box for a replacement. I'm done fooling around with it.
While I've had good weather to work on it I've been fixing up other things on the tractor. I have been hearing a knocking sound coming for the engine since I bought the tractor. I tracked it down to the upper end and thought that there might be a stuck tappet . I removed the rocker cover and checked the clearances on all the rockers. They were all okay. That made me scratch my head. I put things back together and listened to the engine again using the garden hose as a stethoscope. I finally found the noise. There is a leak in the exhaust manifold in the center ports. What brought my attention to this, other than the sound, was the exhaust soot all over the engine block. DUH, how I missed that before is a puzzle. I'm also replacing the gas gauge. That has been an education too, but I'm sure it's the gauge and not the sending unit. Then I move on to the fast hitch. I'd really like to have the draft lever working. The control valve under the dash has a short lever on it to raise and lower the hitch. I'd like to be able to hook up the draft control linkage to this so I can use the draft lever beside the seat to raise and lower the hitch. Instead of having to bend over and reaching for that short lever. When I do that I can't see the hitch. This makes hooking up to anything nearly impossible.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
